REDO10
April 20, 2023, 4:49pm
1
Hi All,
Wanting execute the script related to my thread Offsetting and rotating arcs by overlapping , I noticed that I end up with one extra arc in each curves list
for example in the image below, in the first list I have a circle with a perimeter = 75.08 m, by rotating and overlaping the arc I should get (6 x 12 + 8.68) but I get (7 x 12 + 8.68)…I dont know where I was wrong??
here my script:
rotating arc
import sys
import math
#Circle inputs
circle_curve = IN[0]
offset_distance = IN[1]
rebar_Diameter = IN[2]
overlap_length = 50 * rebar_Diameter / 1000
# Circle's center point
Center_point = circle_curve.CenterPoint
radius = circle_curve.Radius
circle = Circle.ByCenterPointRadius(Center_point, radius)
Start_pt1 = circle.StartPoint
End_pt1 = circle.PointAtSegmentLength(12)
arc = Arc.ByCenterPointStartPointEndPoint(Center_point, Start_pt1, End_pt1)
Radius = Line.ByStartPointEndPoint(Start_pt1, Center_point)
# vector to offset circles inwards by offset_distance
offset_vector = Radius.Direction.Normalized()
Normal_vector = Vector.ByCoordinates(0, 0, 1)
lst = [circle]
lst1 = [arc]
#Offset circles inwards
k =0
d = 0
while k < 600:
k +=1
d += offset_distance
circle_offset = circle.Offset(-d)
try:
Radius_offset = circle_offset.Radius
except:
circle_offset = circle_offset.Explode()[0]
Start_pt1 = circle_offset.StartPoint
End_pt1 = circle_offset.PointAtSegmentLength(12)
if circle_offset.Length< 12:
break
# filling in arcs in lst1
lst1.append(arc)
out = []
for i in lst1:
temp = []
Start_Angle = i.StartAngle
End_Angle = Start_Angle + i.SweepAngle
temp.append(i)
k = 0
while k < 500:
k += 1
overlap_Angle = (overlap_length * 360) / (2 * math.pi * i.Radius)
# compute remaining arc
rest_Arc = Arc.ByCenterPointRadiusAngle(Center_point, i.Radius, End_Angle - overlap_Angle, Start_Angle + overlap_Angle, Normal_vector)
if math.ceil(rest_Arc.Length) < 12:
temp.append(rest_Arc)
#temp = [c for c in temp if c.Length > overlap_length]
out.append(temp)
break
#rotate arcs
i = i.Rotate(Center_point, Normal_vector, i.SweepAngle - overlap_Angle)
#update End_Angle
End_Angle = i.StartAngle + i.SweepAngle
temp.append(i)
OUT = out
Please check my attached dyn file and my Revit model below for more details
test_radier.dyn (20.0 KB)
test_radier.rvt (3.5 MB)
Thanks.
REDO10
April 23, 2023, 1:20pm
2
@c.poupin
Please, can you take a look at my script and see what’s wrong? (I get the 1st arc duplicated twice in each sublist!!?)
Thanks.
@REDO10 ,
a ducktape would be the node rest of items - rest of items.
KR
Andreas
Seem End_Angle is not updated at first iteration in while loop
I didn’t have time to look for the reason (maybe a problem with local variable).
you have to debug all your variables (rest value, arc direction, etc…)
a temporary fix waiting to find another solution
import sys
import math
#Circle inputs
lst = [circle]
lst1 = [arc]
k =0
d = 0
while k < 600:
k +=1
try:
except:
break
lst1.append(arc)
out = []
for idx, i in enumerate(lst1):
print("##### Start a new Arc processing at {} #####".format(idx))
temp = []
sweep_angle = i.SweepAngle
End_Angle = Start_Angle + sweep_angle
temp.append(i)
k = 0
while k < 500:
k += 1
print('rest_Arc.Length', rest_Arc.Length)
if math.ceil(rest_Arc.Length) <= 12:
if k == 1:
temp[-1] = rest_Arc
out.append(temp)
break
#rotate arcs
i = i.Rotate(Center_point, Normal_vector, sweep_angle - overlap_Angle )
#update End_Angle
End_Angle = i.StartAngle + sweep_angle
temp.append(i)
OUT = out
REDO10
April 24, 2023, 8:35am
5
@Draxl_Andreas
It’s a quick solution that’s surely avoid me loosing time and save me a lot of thought.
Thanks.
REDO10
April 24, 2023, 8:52am
6
Ok… I’ll try your code and debug all my variables and see how it goes
Thanks.
To get rid of duplicated geometries you can use the node called PruneDuplicates
Here’s the doc: Dynamo Dictionary
REDO10
April 25, 2023, 7:34am
8
@c.poupin
your code works and the arcs count is correct, but when debugging “rest_Arc” I get the 1st one duplicated…that’s mean I’ve problem with the arc start point? (see the image below)
Thanks.
Because the End_Angle is not updated at first iteration in while loop
I did not look for the cause as mentioned in my previous message
REDO10
April 30, 2023, 9:51am
10
I tried to find the reason why the variable End_Angle is not updated at first iteration but I couldn’t find the solution
I accpet @c.poupin ’s solution at the moment as a tomporary solution.
