Remove Associated Global Paramer
Hello everyone,
I want to set none for all family instances that have been Associate Global Parameter. Right now I’m solving it by removing Global Parameter and then recreating it, but it doesn’t seem to work very well.
Thank you so much.
1
2
a solution with Python
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def toList(x):
    if isinstance(x, list):
        return x
    elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
        return x
    else :
        return [x]
lstelems = toList(UnwrapElement(IN[0]))
paraName = IN[1]
for elem in lstelems:
    para = elem.LookupParameter(paraName)
    if para.CanBeAssociatedWithGlobalParameters():
        para.DissociateFromGlobalParameter()
OUT = lstelems
