'FamilyInstance' object has no attribute 'LookupParameter'
This is weird, API docs says it has such a method: FamilyInstance Methods
Still, Dynamo claims it does not:
this is Revit 2021.4 and Dynamo 2.6
@danail.momchilov ,
maybe it is a library issue use the template:
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
OUT = element
https://primer.dynamobim.org/10_Custom-Nodes/10-6_Python-Templates.html
you have also to Unwrapping your elements!
@Draxl_Andreas Thank you for your answer and suggestion!
I saw what’s wrong:
Had to Unwrap the list (just like you said) and then actually extract the value from that parameter :slight_smile:
This article look at the issue of unwrapping revit elements and why it is required (sometimes).
@Antonio_Vachev,
it is like eating a banana you have to unwrap it, to have more options:
That’s a nice comparison :grinning:
@danail.momchilov i love cooking, but not cleaning the kitchen.
me too, actually…
Where is that link?
yeap, I was curious also
Dynamo DACH Usertreffen 8.12.2020 I Autodesk - YouTube @jacob.small @danail.momchilov
When i would write a manuel for dynamo and Revit API. Maybe you would have been any ideay of it, BUT you would be a great Cook :slight_smile:
That is hands down my favorite diagram for unwrapping ever. It should definitely be in the Dynamo Primer in and future incarnations if not. Needs a ‘forgot to unwrap’ diagram too showing a sad banana sitting in an icecream bowl with skin on.
I try to think in pictures… …to understand programming is difficult… :slight_smile: @GavinNicholls
