Hi All,
Is it possible to reload document in the same dyn file to get datas from the 1st python script needed to run the 2nd python script?
In my case I want to get the container host datas generated in the first file (rebar creation) to be able to copy them to others elements (in the same file) without need to create 2nd file ?
here the 2nd script for copying rebar containers
import sys
import System
from System.Collections.Generic import IList, List
clr.AddReference('RevitAPI')
all_Shafts = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_GenericModel).WhereElementIsNotElementType().ToElements()
# get the remainder rebar hosts.
New_rebar_hosts = all_Shafts[1:]
# Get rebar containers.
first_rebarHostData = RebarHostData.GetRebarHostData(all_Shafts[0])
first_containersInHost = first_rebarHostData.GetRebarContainersInHost()
old_containerIds = List[ElementId]([c.Id for c in first_containersInHost])
# Get levels for remainder rebar hosts.
levels = []
for host in New_rebar_hosts:
level = doc.GetElement(host.LevelId)
levels.append(level)
new_containerIds = []
for l in range(0, len(levels)):
t = XYZ(0, 0, levels[l].Elevation)
containerId = ElementTransformUtils.CopyElements(doc, old_containerIds, t)
new_containerIds.append(containerId)
new_containers = []
for i,j in zip(range(0, len(new_containerIds)), range(0, len(New_rebar_hosts))):
temp = []
for id in new_containerIds[i]:
container = doc.GetElement(id)
container.SetHostId(doc, New_rebar_hosts[j].Id)
temp.append(container)
new_containers.append(temp)
OUT = new_containers
Thanks.
