Reference Plane host Elevation From Level Problem
Sorry for bad english. (google translate)
I have a problem with placing family with Dynamo in Revit.
When I place a family with Dynamo the Reference plane parameter is locked of the revit element.
Elevation From Level should be 2750.0, but appears to be 0.0.
how can I solve this?
ꟿ FamilyInstance.ByHostAndPoint code:
clr.AddReference("RevitAPI")
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
host = UnwrapElement(tolist(IN[0]))
ftype = UnwrapElement(tolist(IN[1]))
fpts = UnwrapElement(tolist(IN[2]))
OUT = []
strt = Autodesk.Revit.DB.Structure.StructuralType.NonStructural
ftp_len = len(ftype) == 1
hst_len = len(host) == 1
for i in xrange(len(fpts) ):
	p = fpts[i].ToXyz(True)
	j = 0 if ftp_len else i
	k = 0 if hst_len else i
	try:
		if not ftype[j].IsActive : ftype[j].Activate()
		level = doc.GetElement(host[k].LevelId)
		nf = doc.Create.NewFamilyInstance(p,ftype[j],host[k],level,strt)
		OUT.append(nf.ToDSType(False))
	except:
		OUT.append(None)
Does anyone have a different solution suggestion on this issue?
Hello @arthassss
try to use this method
https://www.revitapidocs.com/2021.1/be4b822c-829a-7e7b-8c03-a3a324bfb75b.htm
or this node
Unfortunately, I do not have enough information to execute the codes in the link you sent.
I also get an error with the node as below.
@arthassss
you need a Reference instead of the ReferencePlane
implement this in your 1st Python Script
https://www.revitapidocs.com/2021.1/825a593b-4acc-c2ad-9df7-b281a3a2575b.htm
Use the Element Reference node to obtain a reference (Autodesk.DB.Reference) from the Reference plane.
Hello @c.poupin
Frankly, I’m new to dynamo and I know very little about python.
I have no idea where exactly to add the code you mentioned.
Is it possible for you to send the entire code?
Hi @Alban_de_Chasteigner
problem solved.
Thank you for your interest.
