Redraw Line From CAD Layer
Hello friends. I just started to get acquainted and learn Python Script, hope you guys can help me answer this problem. I try to draw line from Autocad Layer, for example i have 3 shapes with layer name 0, when i draw line from layer 0 this can only make 1 shape, is there any way i can draw line for 3 shapes is the class name 0 or not? Hope you can help. Thanks very much
import System
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
import collections
importDWG = UnwrapElement(IN[1])
nameOfLayersToImport = IN[2]
def tolist(object):
	if hasattr(object, "__init__"):
		return [object]
		return object
Tolist = tolist(importDWG)
def GetGeometry(element):
	opt = Options()
	opt.ComputeReferences = True
	opt.IncludeNonVisibleObjects = True
	opt.View = doc.ActiveView
	geometry = element.get_Geometry(opt)
	return [i for i in geometry]
getgeo = [GetGeometry(i) for i in Tolist]
def Flatten(listelement):
	if isinstance(listelement, collections.Iterable):
		return [element for elements in listelement for element in Flatten(elements)]
		return [listelement]
flattenlist = Flatten(getgeo)
def CreateLine(getgeo):
    Points = []
    for geo_int in getgeo:
        geo_ele = geo_int.GetInstanceGeometry()
        for polyline in geo_ele:
            element = doc.GetElement(polyline.GraphicsStyleId)
            is_target_layer = element.GraphicsStyleCategory.Name == nameOfLayersToImport
            is_polyline = polyline.GetType().Name == "PolyLine"
            if is_polyline and is_target_layer:
                pts = polyline.GetCoordinates()
                for p in pts:
            	    Points.append(p.ToPoint())
                line = []
                for i in range(len(pts)):
                    while (i< len(pts)-1):
                        l = Line.CreateBound(pts[i],pts[i+1])
                        line.append(l)
                        break
	return [i.ToProtoType() for i in line]
cre = CreateLine(flattenlist)
OUT = cre
Why don’t you use BimorphNodes?
