Hi!
Has anyone tried to recreate the same function as “FEATUREELEVSFROMSURF” but with if you have polylines with a low amount of vertexes and a tinSurface? I’m after the “Insert intermediate grade points”-effect so the polyline gets the necessary vertexes added.
I know there’s some nodes like “pull onto surface” and so on but these require you (from what I know) to transform the TinSurface to a Dynamo Surface, and I almost always work with very large tinsurfaces so it usually just crashes the instance or just gets stuck loading.
