Record RVT link position using python
Hi all,
I need to record the position of my revit links using python or any Dynamo node, like the image bellow:
Then I have to duplicate the positions and create the same number of buildings.
So, after all, I’ll have all my buildings matching name with positions
I tried to find any way to do this using Dynamo nodes, but I didn’t find any.
I tried to find a way to write a python script to solve this, but, as I’m not a programmer, I’m getting a bit confused with the translation from C# API methods, found on API’s documentation, to Python scripting.
I found out this method that may solve my issue, but I’m not understanding how to use it. It requires an instance of ISaveSharedCoordinatesCallback, and I have no idea of how to set this.
https://www.revitapidocs.com/2015/2bfb9cc1-5a29-a195-0892-92bef673ab66.htm
If someone knows how to use this method or any other method that halps me, I would be thank for good.
My graph:
By the way, I stated this python code:
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
#Get current document
app = uiapp.Application
#setting variables
linkins = UnwrapElement(IN[0])
salvos = []
#start transaction
for link in linkins:
	linkDoc = link.GetLinkDocument()
	type = doc.GetElement(link.GetTypeId())
	opt = SaveModifiedLinksOptions.SaveLinks
	type.SavePositions(opt)
	salvos.append(type)
#end transaction
OUT = salvos
Hi @mayconrfreitas,
You need to create a class which inherits from the ISaveSharedCoordinatesCallback interface. This class should contain the definition (GetSaveModifiedLinksOption(self,RevitLinkType)) as specified in the interface methods. This takes an instance of this class and the RevitLinkType and you use this in the RevitLinkType.SavePositions() method. See the code below…
# Import RevitAPI
# Class inherited from ISaveSharedCoordinatesCallback interface...
class SaveSharedCoordinatesCallback (ISaveSharedCoordinatesCallback):
	def GetSaveModifiedLinksOption(self,revitLinkType):
		pass
#setting variables
linkins = FilteredElementCollector(doc).OfClass(RevitLinkInstance).ToElements()
salvos = []
#start transaction
	#Create instance of callback class
	cBack = SaveSharedCoordinatesCallback
	# Use callback class GetSaveModifiedLinksOption method passing class instance and Revit Link Type...
	t = type.SavePositions(cBack.GetSaveModifiedLinksOption(cBack(),type))
	if t:
		salvos.append(type)
		salvos.append(None)
#end transaction
OUT = salvos
Hope this helps…
Cheers,
Dan
Hi @Daniel_Woodcock1, thanks for you reply, but it didn’t work. It runned no errors, but my link instances kept not shared
Hi @mayconrfreitas,
I’m not sure this is possible with the API. I have been digging around about how to set the shared site or the RevitLinkInstance and saw this quite recent post on the Revit API Forums…
https://forums.autodesk.com/t5/revit-api-forum/how-to-set-quot-shared-site-quot-for-linked-revit-model/m-p/8637780#M37211
I’ve tried various things all to no avail…unless someone else knows of a way, I don’t think this is possible yet.
Cheers,
Dan
