You’re using a node that specifically gets the host element. Just remove Properties.RebarHostElement from the workflow and see what happens.
I don’t think rebar has geometry like other modeled elements. It’s a system family and doesn’t really act the same way. It does just have a parameter, Reinforcement Volume, that gives the total volume of the rebar system. You can also just calculate the volume from the cross-sectional area and bar length.
Which node should I use? I didn’t get that node from my library, sir.
You can use the out of the box GetParameterValueByName node to get any of those parameter values.
Thanks Sir, I would try your advice.
