Hi @Anicius ,
what is your Revit version ? is it Revit 2019 ?
NLH
July 29, 2018, 4:49pm
23
Hello there,
Any update about the rebar.bycurve issue? I’m getting other kind of error message:
Plaese beware that I’m relatively new to Dynamo for Revit, I’ve been trying to add vertical distributed rebar to curved walls using this (thanks to @Dieter_Vermeulen for his Dynam(o)ite course at AU 2016), but Im currently struggling with this node.
Any advice or update? Thanks.
Are you also using Revit 2019 ?
Please follow the instruction as described in the Readme for now:
# Important Note for the latest release for Dynamo 2.0
Please download the latest package and then replace the DynamoRebar.dll in
%AppData%\Dynamo\Dynamo Revit\2.0\packages\Dynamo for Rebar\bin
with this DLL:
https://github.com/tt-acm/DynamoForRebar/blob/master/DynamoRebar.dll?raw=true 4
We’ll update the package again soon. Until its up to date, please replace the file manually and make sure the dll is not blocked (Properties > unblock)
# DynamoForRebar
A Dynamo package for authoring geometrically complex rebar models in Revit 2016.
Dynamo for Rebar is an Open-Source project available on github and [Dynamo’s package manager](http://dynamobim.org/). The library contains a set of nodes helping you to create bars and containers in Revit, and provides a set of nodes for creating the base curvature of single bars or entire rebar containers.
The project is being developed in C# using Visual Studio, and will work with Dynamo 0.8.0, and Revit 2016. The project consists of two libraries; one is a [zero-touch library](https://github.com/DynamoDS/Dynamo/wiki/Zero-Touch-Plugin-Development) containing most of the nodes, the other is a UI library containing a few nodes with dropdown elements.
### Rebar Nodes
The nodes in this group are specific to the [Revit](http://www.autodesk.com/products/revit-family/overview) 2016 Rebar API. They are the core nodes in the package that allow for parametric rebar design in Dynamo. The utility nodes and nodes for curve generation (outlined below) are designed to work well with these rebar nodes.
#### Create Rebar
Creates one single bar element in Revit from a curve and and a series of rebar properties.
This file has been truncated. show original
the problem is I don’t have permissions to update the package at the moment.
NLH
August 2, 2018, 11:40am
27
Hi Maximilian and thanks for the update,
I’ve replaced the dll file as specified in the readme but I still got the same issue…
Please notify us here when there is an update about this package.
Best regards.
Dear @Maximilian_Thumfart1
Still Rebar.bycurve node is not working. please help.
Hi Mohammad, please read the error message: Unable to make wire from edge body: Self Intersects. Looks like your input geometry is not valid. Make sure your input geometry is fine. Sometimes it helps to rebuild it, because it looks like there are self-intersections.
FYI: the latest dll is working fine and tested. We’ll update the package as soon as possible.
Hi!
There is any updated version Dynamo for Rebar available Revit 2020?
Any update DynamoRebar.dll for revit 2020?
Hi, I can build you a version this weekend.
I’m having the same problem as in my original post (top) again.
Dynamo core 2.13.1.3887 Using Revit 2023.
Any ideas ?
Problem solved. Updating to a newer version of Dynamo for Rebar did the trick
