Rebar at Irregular Shape
I add Rebar to this shape with Free Form Rebar in Revit
It’s only work for Single
If I chage to Fix Number 3 It form shown in figure
I want to add rebar around pipe
Can I make this with Dynmo?
Plz give me solutions
Single is OK but it is not OK for other Options like Fix Number and Maximun Spacing
and also for Copy
Hi Ko, welcome to the forum :wave:
Please take the time to read the forum FAQHow to get help on the Dynamo forums
It is most likely you can develop a dynamo graph to assist
Is it possible to show a real-life example (photo or drawing) of what you would like to achieve in Revit / Dynamo?
Yes I can give you Revit File
It is possible to add Rebar to this type of Shape?
Get the outer pipe surface, offset for cover then use the Point at UV values and create curves from points
Can you do this for me ?Because I found a lot of error. I will sent this RVT file to you
Please give me your email or something to sent this Revit File.
