On line 35 how to i ask python to read elements inside the list “ids” and “newlocs”
i tried “ids[i]” and “newlocs[a]” but no luck…!
and here is the error message…
The issue isn’t iterating, it’s that the method you’re using requires an ICollection, not a normal list.
Here’s how you create an ICollection:
elements = UnwrapElement(IN[0])
ids_collection = List[ElementId](e.Id for e in elements)
@Nick_Boyts , thanks for reply,
adding this line to code gives a cast object error…! can you help me understand this error and what exactly I collection command do…!
Is it like wrapping the element again so the Revit could take it…?
the error message:
File “”, line 36, in
TypeError: Unable to cast object of type ‘System.Int32’ to type ‘Autodesk.Revit.DB.ElementId’.
do I have to import and module to solve this??
A Collection is just a Revit set of elements. Certain methods require Collections instead of simple lists. Someone else might have a better understanding of the reasoning behind it.
We specified that your Collection would contain Element Ids, but your new error is saying that you’re trying to cast Integers. I think the issue is coming from your For Loops, specifically Line 31 for Ids. You’re getting the Id of i and THEN Unwrapping it. Try Unwrapping i before getting the Id.
You’ll have to show what your inputs are so we have a better idea of what’s going on.
@saju_autodesk To help others understand better it would help to try explaining with complete graph with preview of all the node values if you want others to help you.
here is the full screenshot
and the error message:
and here is the code:
clr.AddReference('RevitAPI')
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
doc= DocumentManager.Instance.CurrentDBDocument
text=UnwrapElement(IN[0])
locs=UnwrapElement(IN[1])
ids=[]
newlocs=[]
for i,j in enumerate(text):
ids.append(j.Id)
idsc=List[ElementId](ids)
for a,b in enumerate(locs):
newlocs.append(b.ToXyz)
newlocsc=List[ElementId](newlocs)
Move=ElementTransformUtils.MoveElements(doc,idsc,newlocsc)
OUT = IN[0],ids,newlocs
@saju_autodesk Please re-post your graph we can’t read. Use camera button (top-right) built into Dynamo - it screenshots the entire canvas.
edited on the same post…! plz have a look
