ICollections
Hello ,
when im try use next method : (try create ICollections)
clr.AddReference("System")
Ids=List[ElementId]()
for i in IN[0]:
	Ids.Add(UnwrapElement(i).Id)
have a next trouble : ElementId is not found
In IN[0] im give pipe insulations or any another elements from revit
whats the problem?
Solution:
Shoud be import Revit API for detect ElementId
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import * #use ElementId
from System.Collections.Generic import * #use LIST
if isinstance(IN[0],list):
	els = UnwrapElement(IN[0])
	els = [UnwrapElement(IN[0])]
lst_id = []
lst =[]
for i in UnwrapElement(els):
	lst_id.append(i.Id)
icolls = List[ElementId](lst_id)
OUT = icolls
@erfajo thanks to show me this shortest and easy way)
