Random Quad Panel issue
Hi guys,
I’m trying to make this pattern using Lunchbox Random Quad Panel. I have done it in Grasshopper but I couldn’t make it in Dynamo.
Here is the pattern in Grasshopper
And here is it in Dynamo as you can see something went wrong when I used the Random split list tool.
When I deleted the Random Split List tool the function worked fine but the result is not what I wanted. I need it to be splitted.
Sorry for uploading the pictures on Google drive but as a new member I can’t upload more than one picture.
In this link, there are the Dynamo and family files.
https://drive.google.com/drive/folders/1JPQyy9yfdxxV_mNtZBThPZ6-rcAbSmms?usp=sharing
Thank you.
Could you clarify the problem? It didn’t seem too far away?
My issue with these kinds of things is that you always want to manually prune the ‘random’ numbers to make the pattern more pleasing :stuck_out_tongue:
Cheers,
Mark
Thank you Mark.
What I did wrong here? By the way, I’m a beginner in Dynamo.
If possible can you upload your Dynamo file.
Thanks again.
this custom node is not executing - add a seed input. (note how the custom node is light grey)
