Radial Grids
@Marcel_Rijsmus great start…but I think there is more to the question, than what you have answered here.
Mainly that aside from the Grid.ByLine the OP can create more complicated Grids using the Multi-Segment Grid class. I talked about creating those here: Multi-Segment grids
Now in this particular case we are dealing with simple line based grids as well as potentially a multi-segment grid where multiple arcs/lines would be used to create it. Please keep in mind that MultiSegmentGrids can only be created from Lines and Arcs. Below is a little bit more robust interpretation of the answer that @Marcel_Rijsmus posted.
Couple things worth noting:
  • I added a Element.SetParameterByName node at the end of the routine for creating the linear Grids. I bet that creating grids is not the end of the road here. Vertical grids usually have numbers i think. The other ones would have letters. (I will leave that for the OP to sort out)
  • I also broke down the ellipse curve into lines and arcs, so that OP understands the kind of input that is needed for the multi-segment grids.
  • There are nodes that trim the ellipse at start and end. The reason I did that was to make sure that the curves that we are feeding into the MultiSegmentGrid creation python nodes, is not a closed curve (circle, ellipse etc.). Revit doesn’t allow closed curve grids. So I basically cut the curve back a little at each end to add a small gap in the curve.
  • just for shits and giggles I also extended the lines a little. it’s just better looking this way.
Result:
Here’s the Python code:
# Copyright(c) 2019, Konrad K Sobon
import Autodesk.DesignScript.Geometry
app = uiapp.Application
clr.AddReference("RevitAPI")
from System import Array
sys.path.append(pyt_path)
def create_grid(type, curves, plane):
	typeId = UnwrapElement(type).Id
	plane = Plane.CreateByNormalAndOrigin(XYZ(0,0,1), XYZ(0,0,0))
	sketchPlane = SketchPlane.Create(doc, plane)
	curveLoop = CurveLoop()
	for i in curves:
		c = i.ToRevitType()
		curveLoop.Append(c)
	gridId = MultiSegmentGrid.Create(doc, typeId, curveLoop, sketchPlane.Id)
	return doc.GetElement(gridId)
try:
    errorReport = None
    output = []
    for i in IN[1]:
    	output.append(create_grid(IN[0], i, IN[2]))
except:
    import traceback
if None == errorReport:
    OUT = output
    OUT = errorReport
