How can I write this line in Python?
StandardPointGroupQuery standardQuery = new StandardPointGroupQuery();
This is written in C#
I created a group and want to add properties to it to include points
Any Help
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for PropertySets
from Autodesk.Aec.PropertyData import *
from Autodesk.Aec.PropertyData.DatabaseServices import *
# Import references for Civil 3D
from Autodesk.Civil import FeatureLinePointType
# Import Dynamo Geometry reference
adoc = acapp.DocumentManager.MdiActiveDocument
cdoc = CivilApplication.ActiveDocument
ed = adoc.Editor
output = []
dataEnteringNode = IN
with adoc.LockDocument():
with adoc.Database as db:
# Place your code below
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
siteG = CivilApplication.ActiveDocument.PointGroups
#siteGctr = CivilApplication.ActiveDocument.PointGroups.Add("aaa")
site = cdoc.PointGroups["aaa"]
pointGroup02 = t.GetObject(site,OpenMode.ForWrite)
Standar = Autodesk.Civil.DatabaseServices.StandardPointGroupQuery()
# Commit before end transaction
t.Commit()
pass
# Assign your output to the OUT variable.,dir(siteGctr)
OUT = pointGroup02,dir(pointGroup02)
code with c#
//standardQuery.IncludeElevations = "100-200";
standardQuery.IncludeFullDescriptions = pStrRes.StringResult;
//standardQuery.IncludeNumbers = ">2200";
//standardQuery.ExcludeElevations = "150-155";
//standardQuery.ExcludeNames = "BRKL";
standardQuery.UseCaseSensitiveMatch = true;
//knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Civil3D-DevGuide/files/GUID-55A8758C-41DF-47F6-A762-F9B87FAA1A54-htm.html
pointGroup.SetQuery(standardQuery);
pointGroup.Update();
