PythonNet and .NET Class Interfaces
for those who work with CPython3 / PythonNet here is a workaround for using .Net class interfaces
UPDATE PythonNet3 engine 1.1.0 see this post
Syntax for general cases
the solution is to create a Class Type (with Namespace) only once and reuse it in subsequent calls.
import System
clr.AddReference('RevitAPI')
import Autodesk.Revit.UI as RUI
from Autodesk.Revit.UI.Selection import *
class Custom_SelectionElem:
    def __new__(cls, *args, **kwargs):
        cls.args = args
        # name of namespace : "CustomNameSpace" + "_" + shortUUID (8 characters)
        # IMPORTANT NOTE Each time you modify this class, you must change the namesapce name.
        cls.__namespace__ = "SelectionNameSpace_tEfYX0DHE"
        try:
            # 1. Try to import the module and class. If it already exists, you've probably already created
            module_type = __import__(cls.__namespace__)
            return module_type._InnerClassInterface(*cls.args)
        except ImportError as ex:
            print(ex)
            # 2. If we get an ImportError, then the derivative class hasn't been built. Build it. Make sure to set the
            #    __namespace__ so that it is created with the appropriate .Net namespace.
            class _InnerClassInterface(ISelectionFilter):
                __namespace__ = cls.__namespace__
                def __init__(self, bic):
                    super().__init__()
                    self.bic = bic
                def AllowElement(self, e):
                    if e.Category.Id == ElementId(self.bic):
                        return True
                        return False
                def AllowReference(self, ref, point):
                    return True
            return _InnerClassInterface(*cls.args)
# usage
for i in range(3):
    RUI.TaskDialog.Show("Select", f"Select a door {i+1}/3")
    ref = uidoc.Selection.PickObject(ObjectType.Element, Custom_SelectionElem(BuiltInCategory.OST_Doors))
    print(ref.ElementId)
Compatibility of this method :
  • Net Framework 4.x
    Revit / Civil 2022 - CPython3/PythonNet2.5 : Yes
    Revit / Civil 2023 - CPython3/PythonNet2.5 : Yes
    Revit / Civil 2024 (Dynamo 2.19) - CPython3/PythonNet2.5 : NO
  • Net Core 8+
    Revit / Civil 2025+ - CPython3/PythonNet2.5 : Yes
    Revit / Civil 2025+ - PythonNet3 : Yes
Note on .NET Class Interfaces with Python:
  • due to a bug with Revit 2024, I recommend staying with IronPython up to and including Revit 2024 (unless this is corrected in a future update).
  • the use of .Net Class Interfaces with out parameters work only PythonNet3 (engine currently being integrated by Team Dynamo)
Example use of .Net Class Interfaces with out parameters work only PythonNet3
import System
class Custom_FamilyOption:
        cls.args = args
        cls.__namespace__ = "FamilyOptionNameSpace_tEfYX0DHE"
        try:
            # 1. Try to import the module and class. If it already exists, you've probably already created it once, so you can use it.
            print(ex)
            class _InnerClassInterface(IFamilyLoadOptions) :
                def __init__(self):
                    super().__init__()
                def OnFamilyFound(self, familyInUse, _overwriteParameterValues):
                    overwriteParameterValues = True
                    return (True, overwriteParameterValues)
                def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, _overwriteParameterValues):
def loadFamily(path):
    opts = Custom_FamilyOption()
    dummyFamily = None
    loadFamily = doc.LoadFamily(path, opts, dummyFamily)
for path in IN[0] : loadFamily(path)
for explanations and more information, I wrote an article about this (use the translation widget if needed)
Wizardy, as always.
Thanks for sharing this!
The latest version of Dynamo PythonNet3 engine (version package 1.1.0) fixes the .NET interface/class inheritance bug, making syntax simpler.
Codes are now going to be
import System
class Custom_SelectionElem(ISelectionFilter):
    __namespace__ = "Custom_SelectionElem"
        super().__init__()
        self.bic = bic
            return True
            return False
        return True
# usage
for i in range(3):
and
import System
class Custom_FamilyOption(IFamilyLoadOptions) :
    __namespace__ = "Custom_FamilyOption"
    def __init__(self):
        super().__init__() # necessary  if you override the __init__ method
for path in IN[0] :
    loadFamily(path)
