Python to Break Up Stacked Walls Using CPython3
I have been using a python script to breakup all the stacked walls in a project. We are finally at a point that we have more projects in Revit 2022 (yes, we upgrade at a glacial pace) and thus the need to migrate to CPython3. I tried to use the Migration Assistant to upgrade the script. However, it does not seem to work.
This is the error produced
Warning: TypeError : No method matches given arguments for CopyElements: (<class ‘Autodesk.Revit.DB.Document’>, <class ‘list’>, <class ‘Autodesk.Revit.DB.XYZ’>) [’ File “”, line 35, in \n’]
clr.AddReference('RevitAPI')
clr.AddReference('System')
collector = FilteredElementCollector(doc, doc.ActiveView.Id)
filter = ElementCategoryFilter(BuiltInCategory.OST_StackedWalls)
stackedWalls = collector.WherePasses(filter).ToElements()
for i in stackedWalls:
    ElementTransformUtils.CopyElements(doc, i.GetStackedWallMemberIds(), XYZ.Zero)
    eId = i.Id
    doc.Delete(eId)
OUT = 0
