Hi All,
If I try to insert the python code below in a code block a get an error. It runs okay in a Python Script node.
is there a solution?
Thanks.
OUT =["Span " + str (i) + " " + “On_Off” for i in range(1,11)]
Hi All,
Thanks.
It’s because of the double quotes . Try this :
“OUT =['Span ’ + str (i) + ’ '+ ‘On_Off’ for i in range(1,11)]”
Thanks that worked!
@salvatoredragotta @Mostafa_El_Ayoubi is right
