Python script error? Reading from CAD
Seeing as you are having a hard time figuring out the python script, you can also try the Pipe.ByLine node from the MEPover package:
The element.Id?
Thanks know there are quite few packages out there. Will try it as last resort
The node worked ok when I tested with some arbitrary points. One thing that is an issue is that you are using all the 2D geometry when you really want to be using a centreline. Also you need to filter out where the lines are too small as this will cause errors and won’t be able to create the pipe.
I would also “zip” the lists for the points in the For loop.
For pt1, pt2 in zip(FirstPoints, SecondPoints):
       #do some work
But you’re getting there. :slightly_smiling_face:
No, the variable SecondPoint is written secondPoint.
Thanks mate really appreciate it
