Detach central problem
Hi
My script wont work and warning as follow:
Does anyone know the reason?
thanks!
you need add a transaction to detech model
#Do Detech Model Code
same :frowning:
maybe need add document event diff becuase you are using open mutiple document, a transaction will be change doc when you open new file project
from Autodesk.Revit.DB import Transaction
t = Transaction(doc, 'Name')
t.Start()
#Do stuff
t.Commit()
with doc is document of file opening
how can I get the doc of file opening?
I just got the file name and path of the model.
I tried GetLinkDocument() but it cant be used on model’s filename.
function OpenDocumentFile return a document for you, let input it for event transaction
