I am trying to create a floor using Python.
I want the floor in a different location.
Can someone help me with how to move the Lines?
I found this:
when I try this I get error
*Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. *
File “”, line 51, in
AttributeError: ‘Line’ object has no attribute ‘CreateTranslation’
# import RevitNodes
# import Revit Services
clr.AddReference("RevitAPI")
# import system.
import System
# get the current Revit document.
floors = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsElementType().ToElements()
levels = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels).WhereElementIsNotElementType().ToElements()
def createCurve():
l = 200
h = 200
p_1 = XYZ(0, 0, 0)
p_2 = XYZ(0, h, 0)
p_3 = XYZ(l, h, 0)
p_4 = XYZ(l, 0, 0)
line_1 = Line.CreateBound(p_1, p_2)
line_2 = Line.CreateBound(p_2, p_3)
line_3 = Line.CreateBound(p_3, p_4)
line_4 = Line.CreateBound(p_4, p_1)
curveArray = CurveArray()
curveArray.Append(line_1)
curveArray.Append(line_2)
curveArray.Append(line_3)
curveArray.Append(line_4)
return curveArray
myVector = XYZ(40,50,0);
crvs=createCurve()
for crv in crvs:
crv.CreateTranslation(myVector);
floorNew = doc.Create.NewFloor(crvs, floors[0], levels[0], Structure.StructuralType.Footing)
OUT = floorNew
Hi @Justin_Wright,
I could be wrong, but I think it might be a simpler proces to move the actual floor after you have created it, rather then the lines. You can use the ElementTranformUtils Class for this:
Python:
# import RevitNodes
# import system.
import System
def createCurve():
l = 200
h = 200
p_1 = XYZ(0, 0, 0)
p_2 = XYZ(0, h, 0)
p_3 = XYZ(l, h, 0)
p_4 = XYZ(l, 0, 0)
return curveArray
crvs = createCurve()
floorNew1 = doc.Create.NewFloor(crvs, floors[0], levels[0], Structure.StructuralType.Footing)
floorNewTranslated = ElementTransformUtils.MoveElement(doc, doc.Create.NewFloor(crvs, floors[0], levels[0], Structure.StructuralType.Footing).Id, myVector)
OUT = floorNew1, floorNewTranslated
Link to the method used.
Mind that you need to to use MoveElements if you’re moving more than one element.
