Python import from collections fails
I want to use Counter (https://pymotw.com/2/collections/counter.html).
Why doesn’t it work?
import System
clr.AddReference("System.Core")
from System.Collections import Counter
Cannot import name Counter
from System.Collections import Counter as testingtesting
Same error
Collections is not a .NET library. It’s a Python library. Just do this:
ok, good to know,
still getting an error. Using dynamo 1.3 which should matter right (both using python 2.7)
Never mind, added the path to the lib.
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
The reason you had to add it is that for Dynamo 2.0+ that IronPython 2.7 is actually shipped with Dynamo as opposed to Dynamo 1.3 where it was installed alongside of Dynamo. Any libraries we would want to reference from python’s lib folder, we had to add that location to the references like you did above. Just FYI.
