Does anyone know if there is a way to stop a python script midway?
For instance, what if I write in an endless loop into the node? is there a way to escape it without shutting down revit?
No, there is a way to write a “while” loop so that it terminates itself even if it spins out of control. Please get into a habit of putting a counter inside your loops and breaking the loop when you reach a limit. That will save you some time in restarting Revit alone…
the halting problem
But if you just want to stop executing the python node you could try using
import syssys.exit(0)
where 0 is whatever exit code you will exit with… this will probably bubble an exception to the python node… potentially causing a crash
I would stick to Konrad’s advice and avoid while loops when unnecessary or build escape counters into them.
Nice read Michael. Thanks for sharing!
Yes, thanks for sharing. I certainly could use “best practices” for scripting.
I do wonder if this may be some functionality that could be added. Somehow I recall that in the days of Basic & Logo (!) one could use <ctrl-G> or <ctrl-C> to stop a loop.
I think that Generative components also has a similar thing.
