Purge code block def from dynamo?
Hi all.
I am experimenting with code block definitions.
I’ve revised my definition.
But dynamo does not seem to update the formula.
Before i used to have 3 variables, but now i only have one.
Before i connected 3 lists: YYYY, MM, DD.
Now i connect to a dictionary instead.
When i enter my formula in codeblock the definition still remember the “old” setup with 3x variables.
The only way to get the formula working the way i intended is to rename the def - thereby creating a new.
I’ve been trying to figure out a way to update or delete existing code block formulas / definitions.
But i cannot find the guidance i need.
Simple full restart of dynamo seem to do the trick.
Still curious of another workaround.
