Process Schedule List - AttributeError: 'List[object]' object has no attribute 'ViewType'
Hi all, I have been recently learning python but cant seem to figure out why this code wont work, i found this code for adding the “HasParameter” Filter onto my schedules which works if you feed the script a direct view but if its a list of views, it throws this error
File “”, line 22, in
AttributeError: ‘List[object]’ object has no attribute ‘ViewType’
Thank you for any help, and a explaination would also be helpful! :smiley:
Code Below:
clr.AddReference('RevitAPI')
def fieldId(schDefinition, fieldName):
	OrderedFields = schDefinition.GetFieldOrder()
	for x,id in enumerate(OrderedFields):
		field = schDefinition.GetField(id)
		if field.GetName() == fieldName:
			return schDefinition.GetFieldId(x)
	return None
schedule = UnwrapElement(IN[0])
OUT = []
if schedule.ViewType == ViewType.Schedule:
	try:
		definition = schedule.Definition
		field = fieldId(definition,IN[1])
		filter = ScheduleFilter(field, ScheduleFilterType.HasParameter)
		definition.AddFilter(filter)
		OUT.append(schedule)
	except:
		OUT.append("Check Field Name")
	OUT.append("Input View is not a Schedule")
@Bladen when dealing with more than one item, in your case a list of items, you need a for loop to make it work, check in the forum for it, there are plenty of examples
ah okay, i assumed the for loop already in the code would of done this, thank you for the reply and infomation.
