I’m trying to get the filters from schedules and the OOTB node gives a strange error.
So I decided to try my hand at making a python script for it. I got it to work better than the OOTB node, but for some reason what it outputs is different.
I guess I could work with it as is, but I just wanted to understand why I’m getting a different output.
What I noticed is if I hook up one of the other OOTB nodes to mine, like ScheduleFilter.Value or ScheduleFilter.FieldId, it tells me that it expects ScheduleFilter but I’m giving it Object[]. While in python, if I tell it to [f.FieldId for f in sfilters] for example, it works fine.
I tried taking a look at the dynamo source code, but I wasn’t able to piece together how they work. I’m relatively new to the API and coding in general.
I pasted my script below along with screenshots of the nodes from the source for reference. If anyone with more experience has any ideas, that would be great.
clr.AddReference("RevitAPI")
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
scheds = tolist(UnwrapElement(IN[0]))
outList = []
for s in scheds:
sfilters = s.Definition.GetFilters()
outList.append(sfilters)
OUT = outList
