Hi there,
Is there any particular reason why when I open Dynamo in Revit 2025.4, the Revit Lookup does not work until I close and reopen Revit?
I do appreciate your help in advance.
Best Regards,
Farshid
Ive had issues with lookup lately also, i believe it is targetting an out of date version of the nic3point package which some custom packages use.
My unfortunate solution was to use an addin manager to disable lookup unless i need it.
try the version 2025.0.7
the bug will be fixed in the next version
Thank you so much for the help!
