example2.dwg (4.0 MB) example.dyn (58.6 KB) Hi, I got a problem, trying to do Solid.Loft, and I see if I changing here the meaning of offset from [2,-2] to [1,-1] or less than later, dynamo didn’t want to do loft.
What’s your Dynamo Graph Geometry Working Range?
Large, and I changed for all working range and nothing is changing
@deakrio try this:
example для Шупенюк Антон.dyn (54.2 KB)
thank you very much, it works)
