Problem with creating profile
I have created a new profile in Dynamo, then I wanted to add PVIs to it, but for some reason the latter was not successful. Do you have any idea what the problem is?
hossz-szelveny_polinom_illesztese.dyn (29.8 KB)
attached the drawing
I think the attachment is missing.
try to delete the profile before rerun.
For this issue I use object delete and [waitfor pass] code block to delete and recreate the profile first in every run.
acad_b46ZXCM8Nn
Hi @kovacsv,
I don’t undestand fully your video, but I manually deleted the generated “empty” profile from the modellspace after the first run and then rerun the process again. The result was the same.
Hi @hosneyalaa,
You certainly haven’t installed the NumPy package yet…
I was trying to show its strage behaviour, but in this case I have no idea. Have you tried changing the lacing options?
Try this
