I followed the solution that was posted time ago (showed on the first picture). When I do the same process, the results are given in different list, not are replaced in just one list.
Why does this happen?
your ootb List.ReplaceItemAtIndex is not the same one as in the first screenshot. That one is a custom node from the clockwork package i believe. The dfference is that the custom one allows to replace items at multiple indexes in one list whereas the ootb one replaces one item per list only.
@paula.segura.h If you’re using one of the more recent builds (1.1), you can try this
Throws an error, but does the needful
