- I have attached a graph created with Dynamo/Revit 2025.
- In the Primer section 7.2 Node to Code example, the graph results in a configuration with many more cubes.
- Prior to the Node to Code operation my graph seems to be almost identical to the example graph.
- When the node to code operation is executed the resulting code is a little different.
Question: How can I change my graph so that my geometry matches the example geometry, and the code inside of the code block matches? Any help would be appreciated. Thanks.
