Possible to convert Feet to Inches and round?
I’m using ‘Element.GetParameterValueByName’ to grab Revit’s native Elevation parameter and ‘Element.SetParameterByName’ to place that Elevation Value into a custom family parameter. Is there a way to convert the Elevation value to whole numbers and in Inches along the way?
For example, The elevation parameter in the Revit project is 5’ 4 9/32", Dynamo writes this as 5.35664386743537, I would like my set parameter value to be this number in decimal inches to the nearest whole number (64)
Thanks!
Try
hmm Convert Between Units will not accept the Elevation parameter
I had the order mixed up, now it works! thank you!
