Populate the NOTES field under the Properties / Extended Data Dialog in civil 3d
can I create a civil 3d dynamo script to populate the NOTES field under the properties - extended data?
Hi @tgortiz,
Yes, you can use the Object.SetNotes node.
what library is it in?
It’s in the standard library unless you’re in an old build. This screenshot is from Civil 3D 2026.0.
thanks
