Polycurve from Curves with Near Start/End Points
Within the image it comprises of 3 curves, therefore 6 points. The highlighted areas comprises 4 points in total, where each pair is a few millimetres from one another.
I sit possible to have potentially many of these placeholders, extract their curves and start/end points, then repair or handle the ‘close vicinity’ points and return new curves?
Can you label what you mean by 3 curves? I see a LOT more than that here.
Yes, I agree with @jacob.small - the question is not clear
It probably more of a simple geometry problem.
If the question is what I think it is:
If the red and green lines are not quite cotangent (and you have 2 intersection points) it is probably easier to project a line from the centre of green circles perpendicular to the red.
Then intersect that black line with either the red or green- to get either blue or purple dots respectively
Is red a circle or a spline ?
Why not run a curve through the four main points and offset the radius of the circles (if all the same)?
If you are trying to build an arc spline you will always have to blend the arcs because geometry
