Good morning group.
I would like to know what node would work for me to give an angle of 45 degrees inward of this polycurve, my idea is to leave it as seen in image two, thank you if you can guide me.
Thanks for answering, but that is not what I am looking for, since I am creating a lower base and another upper base, in order to generate a solid, because I am leaving everything parametric, so my question is specific, and is which node can be used to rotate or give angle to a surface or a polycurve.
This is what I needed, anyway thank you very much for your time.
You are using it as path, no? Do impliment in a topo? Are you making slaps? @ingjaidenrincon
Uff… so you were searching for geometrical concept… puh i have to pass @ingjaidenrincon
