Hello all
I have a question,
How to get lists of points on the panels in the picture. I want to locate the Points on the right corner of the panel that is hidden by the void. The voids are in the family. Is this possible?
Hello all
I have a question,
If the original geometry was a cuboid and axis aligned, you could use a Bounding Box to determine the extents and with a little math (if required) get the desired points.
If you would use Element.Geometry and see what is in the list you get and derive the start/end points of the lines/curves in the list, there might be some logic there.
If you click an object like a curve/line inside the list, it lights up in the dynamo preview.
Tnx guys for suggestions.
Ok, I tried using a bounding box and i got to this point. I understand that I need some trigonometry to get the desired points, but but what are the steps in the dynamo for that (Which nodes?).
An this is my graph
I 'm totally green in dynamo so i need help
Ok, I did it, tnx a lot
But now I have to move those points that mark the middle of the hole to the position of the air terminals as you can see in the picture.
I made a graph but it doesn’t want to take that last step.
Any suggestions?
https://drive.google.com/drive/folders/1q1Ok33LtKtLtsKlAbJHeTYEURh8Awfzo?usp=sharing
Here is my dynamo script and demo project.
