Hello all
How to link Mtext content with X & Y to a circle that is closer to it than the rest of the circles
Arrange in order of proximity
to form a point from (X & Y FROM a circle & Mtext content)
SORT_PONT&TEXT_TOCIVILPOINTS 01.dwg (917.5 KB)
SORT_PONT&TEXT_TOCIVILPOINTS.dyn (15.7 KB)
@hosneyalaa you can try with bellow process…
- Find X,Y postion of Mtext (use toolkit node objectextension.getparameter)
- create dynamo points from Mtext (x,y)
- create points at the center of circle.
- use node closestPointto to find the nearest points between the two geometry points.
you can give it a try.
Thanks @shahid.shaikh_C3D
I will try
hi @shahid.shaikh_C3D
You have reached this stage
I didn’t understand how LOOP works on all points
If you have enough time, help
SORT_PONT&TEXT_TOCIVILPOINTS 01.dyn (46.2 KB)
Apologies, i thinki i missed something the closest point wont work for all points.
The solution is from this link
With a little modification
closest-point-from-long-list-to-a-point-in-a-shorter-list
import sys
# Inputs
short_list = IN[0]
long_list = IN[1]
# Output list
result = []
# Loop check for each point in the short list
for s in short_list:
# List for distances
dist = []
for l in long_list:
# Distance to point s
d = Geometry.DistanceTo(s,l)
dist.append(d)
# Lowest distance in list
min_d = min(dist)
# Index of lowest distance in list
min_ind = dist.index(min_d)
# Get the closest point from the long_list
closest_p = long_list[min_ind]
# Add the point to the results, as it is the closest to the point from the short list
result.append(closest_p)
# Output the results
OUT = result
Thanks for sharing this.
