Hi I’m new here
can someone help
me place a pyramid shape ontop of this solid
Amigo @khuthuie15 buenas. Using your same methods, the piramide there are not a single solid only 4 surfaces, i hope this works for you!
Nice obelisc by the way!!
Thank you sooo much
What do I type or do to get this
You simply use a “Code Block” node, and type in what you see
Srry broo, is a function of Monochle package, as Sol says Type the content in a code block, the sintax: a[0]; Works also well!!
hi, i am trying to apply a material to the mass but keep getting a warning message saying “mass contains both solid and mesh geometry. mass floors, volume, and surface area may appear incorrect” this causes the edit in place to not appear please help
PS. i loaded this as a conceptual mass family file
