Hello everyone,
Lets say that I have two elements in the family (different footing sizes). I want to place one of those element on a point depending if I write 1800 or 2400 in a string node. I used ‘if’ node to create a condition which used different set of nodes.
The problem is that dynamo places 3 components in general. I know that I can just place one footing and change it parameters but it is not the case.
I want to do something similar with plates family one will be a circle shape and the other one will be a rectangle. I want somehow make dynamo just to use one path of nodes depending what I want.
Is it possible to do? Maybe I should use different set of nodes.
Thanks in advance.
