Place Family Instance through the API
Hi, everyone!
I am trying to place family instances on a face, using the NewFamilyInstance Method (Reference, XYZ, XYZ, FamilySymbol) method.
Here’s the code:
familySymbol = UnwrapElement(IN[2])
refVector = XYZ(1, 0, 0)
for i, plFace in enumerate(IN[0]):
	#faceIfb = ItemFactoryBase(plFace)
	for surface in UnwrapElement(IN[1][i]):
		pt = UnwrapElement(IN[3][i])
		ItemFactoryBase.NewFamilyInstance(plFace, pt, refVector,  familySymbol)
		#ItemFactoryBase.NewFamilyInstance(faceIfb, pt, refVector,  familySymbol)
and I get the following error:
however, if I try to get an ItemFactoryBase object from the PlanarFace, here’s what happens:
		#ItemFactoryBase.NewFamilyInstance(plFace, pt, refVector,  familySymbol)
It says it has no public constructor :tipping_hand_man:
is it then possible to do that through the API?
edit: forgot to mention what my inputs are
so they are PlanarFaces I already got through the API and didn’t wrap , the family type and centerpoints of surfaces for the location
Cheers
@danail.momchilov ,
for placing them you will also need Transactions
KR
Andreas
OMG ofcourse I do… !
I don’t think it would solve it anyway, as I would’ve gotten a warning about that. But let me give it a try :slight_smile:
nope, it’s the same:
@danail.momchilov ,
what your input?
clr.AddReference('RevitAPI')
clr.AddReference('System')
familySymbol = UnwrapElement(IN[0])
refVector = XYZ(1,0,0)
for i, plFace in enumurate(IN[0]):
	for s in UnwrapElement(IN[0][i]):
		ItemFactoryBase.NewFamiliyInstance(pFace, pt, revVector, familySymbol)
OUT = "Placed FamilyInstance"
it looks you have too many
Thx, Andreas, sure the points list is enough, but that doesn’t solve the issue:
t.Start()
	for pt in UnwrapElement(IN[2][i]):
t.Commit()
according to the API doc ItemFactoryBase.NewFamilyInstance() is not a Static method
you need an Revit Document instance to use it with doc.Create
see the example in API Doc
related topic
Thank you so much! I’m not sure I am doing the right thing, but I tried to follow these instructions:
Prior to that I am getting the faces as a reference with Options.ComputeReference = True
I might have progressed a bit :smiley: …but it now seems that the code thinks I am trying to use a method, taking an XYZ as a first argument, while I’m trying to use the reference one:
is there something else I am doing wrong?
You need to convert your Dynamo points to Revit XYZs.
I think that actually worked! just need to tweak it a little bit and convert units for the coordinates
@danail.momchilov ,
:wink:
thx, I was just sharing my thoughts :slight_smile: I am usually just multiplying or dividing by 30.48
Here’s the final code:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import XYZ, Point, FamilySymbol
from Autodesk.Revit.Creation import Document
def cm(a):
	return a/30.48
familySymbol = UnwrapElement(IN[1])
outlist = []
		ptXYZ = XYZ(cm(pt.X), cm(pt.Y), cm(pt.Z))
		instance = uidoc.Document.Create.NewFamilyInstance(plFace, ptXYZ, refVector,  familySymbol)
		outlist.append(instance)
OUT = outlist
thank you all for the support, I am actually not sure who to thank first as I had pretty much everything messed up :smiley: it’s just the first time I was interacting with the Creation namespace
you can use the ToXyz() extension method (conversion)
see here
