In C3D 2024, I can run the script “2022_C3D_DYN_PipeNetwork from Surveydata2” but receive an error message. The pipe network and manholes are created in the drawing.
The pipes are not, although they are displayed in the Dynamo preview.
The Civil3D Toolkit 1.1.12 is also installed.
How can the problem with “PipeNetworkByCurve” be resolved?
In the moment I can’t upload attachments.
What does the error message say on the node? Note that you can read this and copy it directly from the graph node manager under the extensions tab.
Something to be very aware of is that Civil3dtoolkit will not work in civil 3d 2025 and above.
Therefore if you plan to use this version of civil 3d you will need to replace all the Civil3dToolKit nodes with some other method.
I would also suggest you uninstall the current version of Civil3dToolkit and reinstall the later version to mitigate a older version being the issue.
In the prewiew I can see structure and pipes.
