I made a script that will read properties from an excel spreadsheet and then write them to the part.
The problem I’m having is with the PartDataRecord. I am able to get the PartDataField’s ValueList and its items on the first run of a fresh network, change the property and then apply it to the pipe. But when I save and close everything down, then reopen the same network and run the same script, the PartDataField.ValueList returns an error:
“System.InvalidOperationException: It’s not from a fixed list. at Autodesk.Civil.DatabaseServices.PartDataField.get_ValueList()”
Am I applying the PartData the wrong way? I got the method of pipeObj.PartData = pipePartDataRecord from here.
Thank you.
Edit: I recognize I can do this through the Civil 3D Toolkits PartData nodes, I’m just trying to grow some skills via python and the API.
Code:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
cadPipe = IN[0]
errorReport = None
results = []
cdoc = CivilApplication.ActiveDocument
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
try:
pipeObj = t.GetObject(cadPipe.InternalObjectId, OpenMode.ForWrite)
pipePartDataRecord = pipeObj.PartData
pipeBedClsFld = pipePartDataRecord.GetDataFieldBy("PBC")
results = pipeBedClsFld.ValueList[0]
# Commented out for testing. Change pipe's Bedding Class
#pipeBedClsFld.Value = pipeBedClsFld.ValueList[3]
#pipeObj.PartData = pipePartDataRecord
except:
import traceback
errorReport = traceback.format_exc()
t.Commit()
if errorReport == None:
OUT = results
OUT = errorReport
