Hello everyone, I have a question and I do not know if it is possible to automate.
I need to create an assembly number that identifies each tube that has a different length and diameter with a different code.
so that on the table I can extract the quantities of the repeated parts.
I just have not the slightest idea how to get started.
Guys, I can even identify the tubes. But I can not move forward.
Dear friend, it worked! Thank you very much, to be able to evolve my routine more, but now I have another problem.
The sections of tubes that have the same length and diameter are not getting the same numbering. It is the same item copied and it adds with a new numbering.
Sorry for the errors, I’m using the translator.
follows the photo of the complete routine.
Thanks.
basically I wanted the equal values to be quantified as a single object
Use List.UniqueItems
node.
