Pipe Network profile with different elevation at the same station
Hello everybody,
I’m trying to create a profile from a pipe network and basically I’m using two nodes:
but when I have a situation like this:
Screenshot 2021-02-14 153245
it doesn’t work as I would expect:
When I do it manually, I create two PVIs from the profile geometry editor.
I was hoping to be able to replicate this workflow with Dynamo, can anyone help?
Thanks for your help
From my perspective, this is working correctly. When adding PVIs to a profile through the Civil 3D UI, you also can’t add two PVIs at the same station, whether through the tabular editor or inserting them manually. You have to go back and edit the station of the PVI in the grid view. The API method for adding PVIs will throw an argument exception of “Value does not fall within the expected range” if two identical stations are supplied.
This is just background info and doesn’t really solve your problem. I don’t think you’ll be able to get around this by adding PVIs to the profile unless you add a very small increment to the station value so that they are not identical. You could maybe look into adding tangent entities to the profile instead of PVIs.
If the intent of the profile is just for visual purposes, then adding a small increment to the station shouldn’t be an issue. But if you’re using the profile as a source of data for some other operation (like getting the invert elevation of the pipe at any point, for example), then having two PVIs at the same station is probably undesirable anyway because you wouldn’t be able to correctly query the elevation at that station.
Thank you for your answer @zachri.jensen I think I will add a small increment to the station, as you suggest. I just need to follow the pipe slope. Of course I wasn’t say that it’s not working correctly, I was just wondering how the API method works.
You could try and use the ActualInvert nodes in the Toolkit to get the station
Thank you @Paolo_Emilio_Serra1. Can I ask you what’s the difference between ActualInvert and Invert?
The Actual values take into account the slope and rotate the face of the pipe whereas the Invert keeps the faces of the pipe vertical as in Civil 3D. If the pipe has no slope, there is no difference.
Thank you.
I am also new to dynamo, I am also learning how to create profile from pipe, can you send me the dynamo file reference? Thank you so much.
Hi
To solve the problem of adding two PVIs on the same station with a difference in height
You must use this Python
or
That is a change in the connection between the pipe and the manhal
Untitled
Could someone give me some advice on how to create a script to generate a profile at the invert elevation of the pipes in my pipe network? I am new to Dynamo, but perhaps there are nodes in a package that could help me?
Thanks in advance
