Hi All,
I can’t able to get pipe if I select object from data short cut reference
same If i do with pipe object from model I can able to get pipe
how to retreive the pipe from data shortcut reference any idea?
Thank you…
Try to change to code block to the node CivilObject.Name
Hi patrick, still it is same and the pipe is coming from data shortcut reference
Oh, it is a pressure pipe, I thought it was a gradient pipe
Make sure that you use the correct node, there is one for gradient and one for pressurepipes
My group name might be incorrect, but I select a pipe from an dreffed Pressure pipenetwork
