You can use John’s “Rhythm” Package node called Collector.PipeBySystem to get system types. And for collecting pipe fittings for Domestic cold water see below.
I’ve got another question now (lolllll)… but maybe it’s better to create a new post for this…
Do you think it will be possible to see the flow rate for a pipe fitting? (Tee or a bend)
I’m trying to use Dynamo when I want to size pipes (for domestic water)…
I think it will be easy to do it for pipes (I have an equation where if I know the flow rate then I can know the size for the pipe). but what about pipe fittings? How can I know the flow rate from a Tee (I should have three flow rates because a Tee has three connections)…
