Pick new host rebar
pick new host rebar?
Hello! Here is the anwer:
http://www.revitapidocs.com/2018.1/79da5994-50ed-171f-adf2-9a6550c898db.htm
Can you help me creat node?
It depends on how much help you need.
You need two inputs, let’s name them rebarElement and hostElement
Then between transaction start and commit write something like this:
rebarElement.SetHostId(doc, hostElement.Id)
Can you help me write this node?
If you need help to review something wrong in your code, you will find here how to paste what you have done so far:
I tried to do the same thing as pvhuyg and it seems that my Dynamo script can’t access the attribute SetHostID
It also couldn’t get the ID of the desired host element with “hostElement.id”
Is there anything im missing out in the Code?
Edit/Update 1: i found out the element im trying to feed into the Python Script is a RebarInSystem class not the RebarClass. Unfortunately the RebarInSystem class does not provide a SetHostId Method. Still trying to figure out to make it work :confused:
# Phython-UnterstĂĽtzung aktivieren und DesignScript-Bibliothek laden
clr.AddReference('RevitAPI')
import System
# Die Eingaben fĂĽr diesen Block werden in Form einer Liste in den IN-Variablen gespeichert.
rebarElement = UnwrapElement(IN[0])
hostElement = UnwrapElement(IN[1])
# Code unterhalb dieser Linie platzieren
if IN[2]==True:
	rebarElement.SetHostID(doc,hostElement)
	OUT = hostElement
	OUT = "not run"
# Weisen Sie Ihre Ausgabe der OUT-Variablen zu.
Try rebarElement.SetHostId(doc, hostElement) instead.
Thank you @MartinSpence that solved my Problem
Excellent :ok_hand:
hi Martin is there a way to loop through a list of elements (rebars)
Try a for loop
An example for getting the host element Id’s for several rebarElements and storing them in the hostId Array this way:
rebarElements = UnwrapElement(IN[0])
hostId = []
for rebarElement in rebarElements:
	hostId.append(rebarElement.GetHostId())
OUT = hostId
thanks you, but is any idea why i am getting empty list :confused:
comments to your script:
  • U can only assign one host element to a rebar element
  • the second for loop (the inner one) is not necessary as it only changes the hostelement to first one of ur input list and overwrites it with the next one. So every rebar would have the last Element in the list as HostElement
  • u dont need to do list.append for setting a new host. This was only necesary in my example for storing the actual HostId’s in a list.
For setting new Host element to multiple rebars I made this routine, which will only work for assigning a single host element to multiple rebar elements :
import System
if IN[2]==True:
		rebarElement.SetHostId(doc,hostElement.Id)
	OUT = (IN[2],rebarElements,hostElement)
	OUT = (IN[2],"","")
If u want to assign multiple rebar elements to multiple rebar elements u will have to work with proper list structure or doing it with the script above step by step for each host element.
