Pick elements by either drag or click on the elements
Hi all I am trying to use the following python script to pick the objects by clicking on the objects. Reference has been taken from Node for Picking Elements in Order with Revit UI @c.poupin
I wanted include both drag and click option for the user to pick the elements exactly like the node called “Element.PickObjectsByCategory” from DynaMEP. Kindly let me know what should I add to have drag option also in the script.
import sys
import System
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
def overridecolor(elementId, reset = False):
	t = Transaction(doc, "Selection")
	t.Start()
	view = doc.ActiveView
	color_rgb = DB.Color(30,144,255)
	gSettings = OverrideGraphicSettings()
	if not reset:
		gSettings.SetSurfaceForegroundPatternColor(color_rgb)
		gSettings.SetProjectionLineColor(color_rgb)
		gSettings.SetCutLineColor(color_rgb)
		gSettings.SetCutForegroundPatternColor(color_rgb)
		gSettings.SetProjectionLineWeight(8)
	view.SetElementOverrides(elementId, gSettings)
	doc.Regenerate()
	uidoc.RefreshActiveView()
	t.Commit()
	t.Dispose()
flag = IN[0]
selectId = []
TransactionManager.Instance.ForceCloseTransaction()
TaskDialog.Show('Selection', 'Pick elements in the desired order (re-select to Remove), hit ESC to stop picking.')
tg = TransactionGroup(doc, "Selection")
tg.Start()
while flag:
	try:
		ref = uidoc.Selection.PickObject(ObjectType.Element, 'Pick elements in the desired order (re-select to Remove), hit ESC to stop picking.')
		e_id = ref.ElementId
		if e_id not in selectId:
			overridecolor(e_id)
			selectId.append(e_id)
			overridecolor(e_id, True)
			selectId.pop(selectId.index(e_id))
	except Exception as ex:
		flag = False
		break
tg.RollBack()
elemenSelect = [doc.GetElement(xId) for xId in selectId]
OUT = elemenSelect
Thanks in advance
@shashank.baganeACM try this:
mSel = IN[0]
sel = []
if mSel == True:
	ref = uidoc.Selection.PickElementsByRectangle()
	elemenSelect = ref
	ref = uidoc.Selection.PickObject(ObjectType.Element)
	sel.append(ref)
	elemenSelect = [doc.GetElement(xId) for xId in sel]
OUT = elemenSelect
or this:
mSel = IN[0]
sel = []
if mSel == True:
	ref = uidoc.Selection.PickObjects(ObjectType.Element)
	elemenSelect = [doc.GetElement(xId) for xId in ref]
	sel.append(ref)
OUT = elemenSelect
@Elie.Trad thanks for your response. No its not working I mean I am not able to select the elements by drag option.
above scripts only allow me to pick the elements but I want both the options like drag and pick elements
@shashank.baganeACM you can do only one task at a time, either pick or drag-select by specifying the Bool node, I do not know if it is possible to do both at the same time, maybe someone else knows.
Hi @Elie.Trad I found it. I have used part of yous and part of select model elements from Datashapes package and merged it.
It works fine for me and thank you so much for giving me part of the solution. So now I can select elements either by drag or click on the elements.
Thanks once again I really appreciate that you took time for this. The script something looks like below
import sys
import System
	t.Start()
	if not reset:
	doc.Regenerate()
	t.Commit()
	t.Dispose()
class uiselectelements():
    def __init__(self,inputname,buttontext,multi):
        self.inputname = inputname
        self.buttontext = buttontext
        self.multi = multi
    def __repr__(self):
        return 'UI.SelectElements input'
class uiselectelementsofcat():
    def __init__(self,inputname,buttontext,category,multi):
        self.category = category
        self.multi = multi
    def __repr__(self):
        return 'UI.SelectElementsOfCategory input'
if IN[2] == [""]:
	x = uiselectelements(IN[0],IN[1],IN[3])
	if isinstance(IN[2],list):
		catnames = ', '.join([UnwrapElement(i).Name for i in IN[2]])
		if IN[1] == "Select Model Element(s)":
			buttontext = 'Select %s' %(catnames)
			buttontext = IN[1]
		buttontext = IN[1]
	x = uiselectelementsofcat(IN[0],buttontext,IN[2],IN[3])
flag = IN[4]
selectId = []
#TaskDialog.Show('Selection', 'Pick elements in the desired order (re-select to Remove), hit ESC to stop picking.')
tg.Start()
while flag:
	try:
		#ref = uidoc.Selection.PickObject(ObjectType.Element, 'Pick elements in the desired order (re-select to Remove), hit ESC to stop picking.')
			overridecolor(e_id)
		flag = False
		break
tg.RollBack()
#OUT = elemenSelect
OUT = x
and the inputs are
Hay @Elie.Trad if you could reduce the script by removing unwanted things, please post it here the final one which will be fine tuned.
Thanks in advance
It’s necessary to implement a ISelectionFilter class
import sys
import System
	t.Start()
	if not reset:
	doc.Regenerate()
	t.Commit()
	t.Dispose()
class CustomSelectionElem(ISelectionFilter):
	def __init__(self, bic_cat):
		self.bic_cat = bic_cat
	def AllowElement(self, e):
		if e.Category.Id == self.bic_cat.Id:
			return True
			return False
	def AllowReference(self, ref, point):
		return True
flag = IN[0]
bic = UnwrapElement(IN[1])
selectId = []
tg.Start()
while flag:
	try:
		ref = uidoc.Selection.PickObject(ObjectType.Element, CustomSelectionElem(bic), 'Pick elements in the desired order (re-select to Remove), hit ESC to stop picking.')
			overridecolor(e_id)
		flag = False
		break
tg.RollBack()
OUT = elemenSelect
