Parametric paneling (precast concrete)
Sorry guys for not posting anything here. This workflow is applied to the Revit model. I want to thank again to @Vikram_Subbaiah and @Dimitar_Venkov for your help. I got exactly what I wanted in the end. Here are few screen shots of an end product.
Looks great! Would you mind sharing the workflow?
Thanks!
Will try to post something tonight! Are you looking for ripple or twist panel type?
I’d be interested in having a look at both! Thanks. :slight_smile:
Here you go! But you will need surface from revit in order for this to work.Twist_north_v2.dyn (36.3 KB)
Ripple_v3_north.dyn (49.1 KB)
Thank you for your response! In the above picture I redrew the wall as a mass and I’ve been using the script to try to make it an adaptable surface.
Is there another way I can do this? The goal is to have rotating louvers on my wall in Revit.
I am having problems creating the connection between the face of my massing model with the script written in the beginning of the comments. I tried using the toilija’s file but it is creating some default with _array. What other way could I come about this by using the selected mass.
Thank you
